Re: OT: Finally figured out the real reason
Posted by rustyfarmall on August 08, 2008 at 07:36:31 from (209.152.78.71):
In Reply to: OT: Finally figured out the real reason posted by mkirsch on August 08, 2008 at 07:28:13:
I've never seen a driveshaft for rear wheel drive twist in two. I have seen u-joints totally destroyed due to abuse, but the u-joints can be replaced and the original driveshaft will live forever.
