Re: 495 case -ih brakes
Posted by 495man on August 08, 2008 at 15:37:48 from (24.222.9.184):
In Reply to: 495 case -ih brakes posted by coonhound on August 07, 2008 at 16:59:50:
Do what JimB2 says, ours had one brake that kept getting air in it, turns out on the the lines near the hydraulic oil filter came loose 1/2 a turn enough that it would allow air in and you would loose the brake on that side after a while. Tightened the line and no more problems.
