Re: Engine tune-up
Posted by old on August 08, 2008 at 18:35:50 from (4.244.90.168):
In Reply to: Re: Engine tune-up posted by wallacedw on August 08, 2008 at 15:39:21:
Sticking float causes and engine to run way to rich. That in turns cause the cylinder to get washed down by to much gas and that in turns cause cylinder damage due to little or not oil on the rings. And then in turns cause scoring of the cylinder walls and or broken rings etc. Run an engine to rich or to lean either one can/will cause major engine problem that can/will cost big $$ to fix
