Posted by GordoSD on August 08, 2008 at 19:14:09 from (66.115.200.140):
In Reply to: Engine tune-up posted by wallacedw on August 08, 2008 at 14:26:32:
Some basic carb info here. The float, rides on the fuel in the bowl. When you are driving the tractor the needle seat will almost never stick closed. Vibration will open it.
When you park and shut down, the needle may not seat/close. causing leakage. You won't get a rich mixture running from a "sticky needle". You would get zero fuel and starvation.
If the float is set too "high" that is it shuts off late, then you get fuel overflow and leak while running. Too high fuel level in carb doesn't mean too rich. That is determined by the load screw seting to the discharge needle. Float set too low, and then you can have a lean situation.
You need to tell us why you think the carb "float is sticking". Better yet, just send the carb to "rusty farmall" and make sure it is ("100% balls on calibrated,It's an industry term") (from My Cousin Vinnie).
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
