Posted by Paul in MN on August 08, 2008 at 20:05:33 from (207.224.88.88):
In Reply to: H Drawbar posted by GordoSD on August 08, 2008 at 10:25:22:
Gordo,
It may be difficult to bore that hole with a drill bit. Depending on what kind of welding rod or wire was used, it may have many hard inclusions. I would try to go about 150 RPM and keep the drill pressure as high as possible (use plenty of cutting oil).
I welded up the very oblonged hole on the drawbar of my H. But I kept building weld in the elongated part of the hole..let it cool a bit..weld a bit more. Then to smooth it out, I used a carbide die grinder and got it pretty round.
Later I found a welder's trick that would have saved much time. You can buy carbon rods of common diameters (kind of like when we took big dry cells apart as kids). You put the carbon rod in the hole you are rebuilding and weld right up to the rod. The liquid steel does not run away or burn through the carbon rod. Use multiple passes until you have the top weld surface higher than the top of the drawbar. Same on the bottom. Let it cool a bit and smack out the carbon rod. It will shatter and you will have to use a small punch to get the pieces out, but you will have a good round hole and no machining necessary. I wish I had known this before I welded up my H's drawbar hole. Oh well, there will be other tractors with worn drawbars.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
