Re: low compression head for farmall M
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Harold H on March 19, 2000 at 16:16:42 from (207.244.55.214):
In Reply to: low compression head for farmall M posted by dave k on March 18, 2000 at 15:49:34:
The low compression heads were used on the distillate tractors and the kerosene tractors. Both had radiator shutters, heat manifold, & auxilary tank. The distillate tractor had lower compression than the gasoline tractor, and the kerosene tractor had lower compression than the distillate tractor. The distillate option was very common in our area but not the kerosene, which was identical except for the even lower compression ratio.
Harold H
Post A Followup
: Re: Re: low compression head for farmall M
