Posted by Janicholson on August 09, 2008 at 06:08:26 from (66.173.50.88):
In Reply to: SPEED CHECKER posted by donald schnupper on August 08, 2008 at 13:08:17:
Though you can check it, I do not see why if you are just using it. If the tractor goes at the rated speed in gears, Like 16 in fifth at full throttle, it will be fine. The rated speed is just a design idea and equipment spec, not reality. They work in a range from about 600 to 500 RPM all the time. It cannot be higher than that fine range unless the governor has been messed with and it goes faster than 20MPH in High gear. It is not a precision requirement. They did not make 1000RPM shafts in those years, so no risk of that. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
