I am an electrician and have worked on manufacturing equipment for three years. There are alot of control circuits (120 vac, 24 vdc, and analog) that are sensitive to the 480 vac primary power. Analog signals (like telephone) are usually shielded cables and grounded on ONE END. Experimentation yeilds the best results on which end has the least interference. Also, primary and secondary circuits work best if not parallel to each other. If they have to cross, try to do it at right angles (perpendicular). Seems it is more convienent to run them parallel. You may have to relocate the line further away or move the charger.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
