Re: smoke!
Posted by MN Scott on August 09, 2008 at 11:57:18 from (206.9.216.57):
In Reply to: smoke! posted by Jim Isler on August 09, 2008 at 10:27:06:
Did you measure the sleeves with a bore gauge? My guess is a combination of new rings on worn pistons in worn sleeves, worn valve guides/valves. Take it out and work it hard to try to seat the rings, might work but probably not. Unfortunately there is no shortcut to a proper overhaul, new sleeves/rings/pistons, complete head job, new bearings, reconditioned rods ect. I've never had an engine properly overhauled smoke or burn oil on me but I am picky, no shortcuts.
