> The fence and phone cable (underground) run more > or less parallel for about 300 ft, probably > averaging 5 feet or so apart.
That was the cause of your problem. When the fencer puts out a pulse it has to charge the capacitance of the fence. You had quite a bit of fence past the parallel section being driven through it and so quite a bit of charging current flowed there. That current induced current in the phone line, which was the tick you heard. By breaking the fence and feeding it around from the other side you drastically reduced that current. The optimum place to put the break would be in the center of the parallel stretch.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
