Posted by El Toro on August 09, 2008 at 14:29:55 from (205.188.116.73):
In Reply to: smoke! posted by Jim Isler on August 09, 2008 at 10:27:06:
You should've pushed those new rings down into the sleeves and measured the ring gap before installing them on the pistons. You probably should've installed a new sleeve kit and had the cylinder head redone by your local auto machine shop. Your piston rings need to be staggered so all the ring gaps aren't aligned with one another.
Squirt lots of oil into those cylinders and recheck the valve clearance and set them at .020" Cold. Then redo the compression test again. Hal
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
