Re: smoke!
Posted by old on August 09, 2008 at 14:30:15 from (4.245.5.140):
In Reply to: smoke! posted by Jim Isler on August 09, 2008 at 10:27:06:
Well if the ring gaps are as they should be and off set as they should be I would say you did one of the classic mistakes of engine rebuilding. If you do the bottom do the top or the top will go bad fast. If you do the top always do the bottom or the rings will blow out the bottom. So your new rings and now showing you that you have valve problems also and the head need to be rebuilt also
