Re: smoke!
Posted by Dellbertt on August 09, 2008 at 15:09:55 from (209.172.21.62):
In Reply to: smoke! posted by Jim Isler on August 09, 2008 at 10:27:06:
Going by what you have said. If it was mine I would make sure it has plenty of oil and coolant, set it at 1/2 throttle and let it run for about 2 hours to see if the rings burn in.
