Re: shifter rails/forks - reinstall of case cover help
Posted by Brad in WI on August 09, 2008 at 20:07:02 from (69.23.75.255):
In Reply to: shifter rails/forks - reinstall of case cover help posted by dancbtmkr on August 09, 2008 at 19:08:29:
Make sure the gears are in neutral BEFORE you lower the cover down. also have gear shift lever in neutral postion. When lowering come down slowly with a cherry picker or some other means of coming down slow and easy. Use a flash light to look in and make sure that the shift forks come down into the slots on gears. Use a long bar to move the gears slightly to align everything up if not so already. Not a bad job just make sure it shifts correctly before bolting down and starting the tractor
Brad
