Posted by Wayne Mo on August 09, 2008 at 20:28:16 from (207.69.137.35):
In Reply to: Re: Smoking Tractor posted by Janicholson on August 09, 2008 at 05:55:01:
Thanks for the detailed instructions for installing valve seals. I put air pressure in each cylinder and they all held good with just a little noise heard at the crankcase. I put air pressure on each cyl with the intake taped shut and the intake valve open and there was a pretty good whistle of air in each heard at the crankcase. Compression measured 120 in each cyl. I concluded it is the intake valve guides leaking oil. Your idea to replace the seals sounds pretty good. Maybe I should remove the head and replace the guides and or valves. Not sure what to do. I am surprised that worn valve stems or guides would cause so much smoke though! But I really think the rings and valves are sealing ok.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
