Re: 3 point supplier
Posted by andy r on August 09, 2008 at 20:42:17 from (67.224.8.75):
In Reply to: 3 point supplier posted by wallacedw on August 09, 2008 at 17:42:04:
I went to a iron/metal supplier and bought some thick (maybe 1") irons and cut my own adaptors patterned off of two I already had. I just drilled a hole in the implement end to accomodate the two lower points on the implement. Now I can just prop them up and back into the adaptors as I do with the regular IH fast hitch implements. The only exception is to hook up the top link. I have a set for a bush hog and a set for a sprayer. The IH cultivator, IH blade and IH semi-mounter plow all have their own of course.
