Re: F-20 engine build
Posted by spencer13cat on August 09, 2008 at 21:08:05 from (70.232.140.226):
In Reply to: F-20 engine build posted by spencer13cat on August 08, 2008 at 19:14:06:
Not sure what happened on my last post. I show as a guest. Anyway for the benefit of future readers and the many who probably don't know.
Cubic inch displacement is figured
Bore x Bore x Stroke X .7854 x #cylinders
f-20 stock 3.75x3.75x5=70.3125 x .7854= 55.2234cu/in per cyl x 4 cylinders= 220.89 cu/in
4.00" bore 4x4x5=80 x .7854=62.832 cu/in per cyl x 4 = 251.328 cu/in or approx 13% increase in displacement.
Deck height is the centerline of the crank shaft to the top of the block.
