On a negative ground system, the coil's (-) terminal goes to ground, as well, through the breaker points.
Your's is backwards, which makes for a slightly less effective spark at the spark plugs.
When the coil's polarity is correct, the leading edge of the spark at the plugs is negative-going. Since the center electrode is hotter than the ground electrode, this makes it easier for the spark to occur, due to the "Edison Effect". (Electrons are emitted better by a HOTTER object better than by a COLDER object.)
On modern vehicles with a "waste spark" system that fires 2 plugs at once, one fires with (-) polarity and the other of the pair fires with (+) polarity, yet the engine runs well 'cause the ignition system has a HOT enough spark to fire even the reversed-polarity plug efficiently.
On your old slow turning, low-compression tractor, the reversed-polarity coil will be a problem only if the spark is marginal to begin with.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
