Spring loaded brake pedals on an H.
Posted by Pairodox on August 10, 2008 at 17:16:31 from (72.70.210.55):
I'm attempting to prep brake components on my H for sandblasting. I've removed the spring mechanism and can't get it apart to my satisfaction. I've unscrewed the top piece. This leaves the spring still inside its housing. I can't figure out how to get that spring out. Do I have to unscrew the piece at the top of that housing? There's a shaft (threaded on the inside) into which the top piece mentioned above fits ... this runs through the middle of the spring I'm tryingn to remove. Any suggestions? By the way .. this is on an H.
