I'm not an expert on hydraulics by any means, but here are some observations that I think may be valid.
1) I think the power beyond valves should have another line to "dump" the return flow from the cylinders that needs to connect to the reservoir.
2) Connecting the additional valves between the pump and the power steering connections means that your power steering will go away whenever one of the added valves is actuated. Connecting your valves between the power steering taps and the existing remote will give priority to the steering.
3) Raising the relief beyond the factory setting of 1600# will add stress to the pump and gears that drive the pump. You may get away with it. On the other hand, you may blow pump seals and dump Hy-Tran into the engine, may damage the pump, may blow the gear train that drives the pump. You may want to price a pump and a gear set before you boost the pressure.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
