Re: Hydraulic Circuit, Normal and Power Beyond (DIAGRAMS ...
Posted by TractormanNC on August 11, 2008 at 07:41:22 from (209.42.180.55):
In Reply to: Hydraulic Circuit, Normal and Power Beyond (DIAGRAMS SHOWN) posted by charles todd on August 10, 2008 at 17:30:40:
Hey Charles,
Been following your saga for some time as I have a 504 which I recently put P/S on. Agree with Allan about placing power beyond valve between P/S flow divider and aux valves. You will indeed need a return to sump for the power beyond. Only place I know of that is big enough to dump that much oil is the filler plug without tapping another hole in the xmsn case. I don't think the 1/2 inch pipe plug that is the fluid level check/power steering/oil cooler return will be big enough to flow what you need. You have the 17GPM pump if I recall correctly.
