Re: 350 UTILITY TRACTOR OIL LEAK
Posted by Janicholson on August 11, 2008 at 16:57:23 from (66.173.50.60):
In Reply to: 350 UTILITY TRACTOR OIL LEAK posted by DAN STIREWALT, OREGON on August 11, 2008 at 14:43:13:
One of two possible leaks. Trans fluid from TA seals, or trans seal. Engine rear main.
Put a drop of engine oil from the dip stick on a clean white piece of printer paper. then put it under the tractor to get a fresh drop from the leak. If a match it is rear main. Split to fix.
If it does not, it is TA/trans seal. Split to fix.
JimN
