Re: Farmall M Stroker Crank
Posted by TC2 on August 12, 2008 at 07:21:41 from (132.79.8.15):
In Reply to: Re: Farmall M Stroker Crank posted by ChadS on August 07, 2008 at 12:22:59:
Chad, I tried to e-mail you a couple of times with the info you wanted. I am just making sure that you got them. Thanks again for your help!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
