George: Your quite correct, there is a C-123 piston and sleeve kit for block part number 251069 R1 used in Farmall C and early Super A, everything will bolt up even a water pump. jonny should be aware his current sleeves and pistons will not fit block no. 251069 R1.
There is also a C-123 kit for block part number 6342 DH used in A and B tractors, however that block will not be drilled for a hydraulic pump.
Jonny, if not I should have told you before your current sleeve kit will not fit block 366204 R1 used in 130 and 230. The kit currently in your SC will only fit block number 354898 R1 or R2.
If wrong, George, correct me on this, however I think all cranks will interchange.
Today's Featured Article - A Towny Goes Plowing - by Anthony West (UK). I live in an area renowned for its rural beauty. Small fields with hedgerows and trees are common place, as are small hamlets with village greens and the odd duck pond complete with swans. The center of any village once the shop is closed is the old tavern. Rustic places with cheerful names like "The Griffin" "Red Lion" or "The Plough and Harrow" are found dotted around the country lanes all over the place. The warm glow of yellowish light can be seen for quite some distance at dusk, and
... [Read Article]
Latest Ad:
[More Ads]
