Posted by RN on August 12, 2008 at 15:55:58 from (216.165.130.126):
In Reply to: E85 in M? posted by rbower on August 12, 2008 at 15:28:04:
Treat the E85 as dual fuel- start gasoline and switch when warm. IHC had some alky burners in 30s for a couple limited markets- Cuba was one using some ethanol, a couple industrial users around dock areas also used ethanol mixes for safety reasons, less explosive risk and fires could be doused with water. If you're in Minnesota where E85 is becoming more common- consider the highest compression pistons available. Extra fuel filter in line also helpfull, clean fuel tank good and watch carb for leakage, check oil. Gasket and seals in fuel system are main concern. RN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
