Re: E85 in M?
Posted by Steven f/AZ on August 12, 2008 at 16:10:25 from (216.67.213.217):
In Reply to: E85 in M? posted by rbower on August 12, 2008 at 15:28:04:
Higher compression ratio will help alot to take advantage of the higher octane rating of E85...
You may have to drill out the main jet to get enough fuel at full throttle/full power. E85 has lower energy content per gallon so you need to get more fuel through than gasoline.
NO RUBBER in the fuel system - has to be E85 compatible. Some needle/seat had rubber tip that would be eaten away by the alcohol.
Keep the fuel tank full to minimize condensation as alcohol will absorb water and cause problems. Will also clean out any rust, etc.
