Re: Farmall A starting problem
Posted by Janicholson on August 12, 2008 at 21:15:22 from (66.173.50.174):
In Reply to: Farmall A starting problem posted by Vic Bunn on August 12, 2008 at 21:04:29:
If the mag impulse coupling is not tripping, or not loading its trip spring as it should at hand crank speed, it will not start. The impulse should snap loudly when Number 1 passes TDC. If not that impulse is causing the issue. Pull starting spins the mag in the same way it does when running and thus lots of spark. If it snaps, and has spark, I would pull the Sparkplugs one at a time and put a teaspoon full of gasoline in each hole then put the plugs back in and try it. If it fires up, it may not be getting full choke. Check the closure of the butterfly. JimN
