Posted by glennster on August 13, 2008 at 06:26:04 from (75.57.78.225):
In Reply to: Farmall Cub posted by Laine on August 13, 2008 at 06:08:11:
if you have good spark and good fuel, try removing the spark plugs, use a pump oil can and put 2-3 squirts of motor oil in each cylinder, crank the motor over a couple times to distribute the oil, then replace the plugs and try and start it. could be the rings are sticky and the compression is low. if it starts and runs, you could tray and add some marvel mystery oil to the gas and let it run on that for a while. wouldnt hurt to throw some marvel oil in the crankcase too, helps to clean things up.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
