Re: Removing manifold bolts
Posted by Cub n M in OR on August 13, 2008 at 07:57:52 from (4.191.49.203):
In Reply to: Removing manifold bolts posted by Vacherie on August 12, 2008 at 20:07:34:
NOW. This may not be advisable, but it worked for me, when I was taking the manifold off of my M. After hitting them with penatrating oil for a few days, I hooked my impact wrench to the pressure regulator I use when I am spraying paint. I turned it down to like 30 lbs, and let it do its thing. Rattled a little, shook things loose. Turned the pressure up SLOOOWLY. 5 lbs at a time, rattled things some more, let it work for a while. Then finally, it shook em loose.
Like I said, may not be advisable, but it worked on the stubborn bolts I had.
Good Luck,
Ben
