Re: SMTA Starter
Posted by Wayne from MN on August 13, 2008 at 08:05:17 from (66.228.243.49):
In Reply to: SMTA Starter posted by GordoSD on August 13, 2008 at 07:18:13:
Did you replace the original cast metal saddle switch with a newer thin steel switch?
I did and the starter would not work; it shorted the battery to ground.
After 3 switches and hair tearing I found the problem was the original switch mounting screws were 1/8th of an inch too long for the new style switch and when tightened they protruded too far into the starter case & grounded the winding inside the starter!!
2 shorter screws later & the starter worked fine.
Put that tidbit in the file of useful info for the future.
