Re: SMTA Starter
Posted by Bob M on August 13, 2008 at 08:08:33 from (151.190.254.108):
In Reply to: SMTA Starter posted by GordoSD on August 13, 2008 at 07:18:13:
Gordo - Most likely the copper terminal button on the starter has worn so it will no longer contact even a new saddle switch. (Note the terminal button wears away at about the same rate as the contact bar inside the saddle switch...)
As Jim suggests ovalling the switch mounting holes may allow the switch to be moved closer to the button to make good contact again. But sooner or later the starter will need to visit the shop to have a new terminal button installed.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
