Re: Farmall A starting problem
Posted by Janicholson on August 13, 2008 at 11:58:59 from (199.17.61.179):
In Reply to: Re: Farmall A starting problem posted by Vic Bunn on August 13, 2008 at 09:56:57:
Use a plain jane propane torch. Remove the nozzle (not the pipe). With the tractor running (outside) use a modest flow of propane from the pipe to follow around the intake system. especially the gaskets and rear area. If the engine pickups speed, and begins to run better, there is a hole in that location. It adds fuel to an air leak. JimN
