Re: Farmall A Super A weights
Posted by Hugh MacKay on August 13, 2008 at 12:39:05 from (209.226.106.19):
In Reply to: Farmall A Super A weights posted by ABill13 on August 12, 2008 at 15:59:11:
Bill: Super A with front and rear wheel weights and chloride in the rear tires will run awfully close to 3,000 lbs. I expect the A will be the weight of the hydraulic system lighter Probably 75 lbs less than SA.
Not sure I'm getting it right either, front wheel weights are about 35 lbs, rears are 145 lbs each and chloride will be roughly 150 lbs per tire. My SA weighs 2,350 lbs. no wheel weights or chloride.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
