1958 Farmall 340 Hydraulic and Transmission Fluid.
Posted by 1951 8N on August 13, 2008 at 17:46:36 from (209.240.206.194):
Where do you check and add the Hydraulic and transmission fluid on a 1958 Farmall 340? All I have found so far is a threaded plug on top of the transmission to the left the shifter which requires a 3/4 inch drive to remove. Is this the fill plug? If so how do you know when it is full or check the fluid level? What kind of fluid does it take?
