Posted by Haas on August 13, 2008 at 18:01:57 from (12.65.78.192):
In Reply to: Cub Light Won't Work posted by Retcol on August 13, 2008 at 17:48:43:
The painter probably painted some of the mounting work so the light is not getting a ground. Run a wire from a good bare spot on the light mounting bolt back to the battery ground. If the lights work then, check the mounting brackets for paint that could be insulating the light body from ground. If you have a volt meter, you can also check the voltage where the wire connects to the light. If the light switch is on and you have voltage there, it is either inside the light or a bad ground as mentioned above. If no voltage at the connection on the light, then it's in the wiring between the switch and the light.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
