Re: Starts and quits (Farmall B)
Posted by teddy52food on August 13, 2008 at 20:01:06 from (209.237.111.169):
In Reply to: Re: Starts and quits (Farmall B) posted by Bill Carr on August 13, 2008 at 16:33:14:
Is there a magneto shop near you? Maybe the spark is weak after the impulse kicks off. Have them run it and check it at slow speed just after the impulse lets go. If you can get gas to drip by choking,try to leave the choke about 3/4 on instead of opening it all the way. If it stays running it should start to chug and show black smoke. If it does, open the choke just a small amount to let in more air. Is there a main jet adjustment on the carb?
