Valve Seals For Farmall H
Posted by Wayne Mo on August 13, 2008 at 21:06:15 from (209.86.226.11):
I will try to install valve seals for my smoking Farmall H without removing the heads.
Where can I get them and are there different styles or quality seals. I assume they must fit the valve stems tightly and cover the guides during operation. I guess you measure the valve lift and install the seal where it will just bottom out on the guide at the max lift. Shouldn't there be some means to hold the seal securely so it does not ride up or something during operation.
