Posted by Bob M on August 14, 2008 at 07:31:43 from (151.190.254.108):
In Reply to: 6V lighting posted by mkirsch on August 14, 2008 at 06:42:05:
Most "heavy duty" 12 volt flashers will work fine on 6 volts.
All the flasher cares about is the current passing thru it, not the system voltage. So a (2) 6 volt stop/turn bulbs "looks" the same as (4) 12 volt stop/turn bulbs to the flasher. And it will flash 'em just fine.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
