Re: Paul Shulner your attention please
Posted by Hugh MacKay on August 14, 2008 at 18:24:02 from (64.228.11.119):
In Reply to: Farmall C-72, bottm or belly mount blade posted by Mr77FM on August 14, 2008 at 08:41:45:
Amos: Go to the Farmall photo gallery. Type in Farmall Super C. When you come to Paul Shulner's Super C click on it. There is likely more than one of Paul's tractor, however I know there is a photo in there with blade mounted on front.
I changed that title, hopefully we will get Paul's attention. I'm certain he has directions for mid mount as well.
