Re: Farmall C-72, bottm or belly mount blade
Posted by gab on August 14, 2008 at 19:19:05 from (216.82.171.6):
In Reply to: Farmall C-72, bottm or belly mount blade posted by Mr77FM on August 14, 2008 at 08:41:45:
I've got one of those blades on my tractor right now but it did'nt come with the lift linkage. I use chains from the touch control arms. I've got the owners manual somewhere around here too. What do you need a picture of? If I can find the manual and my daughter is around tomorrow night to run the scanner maybe we can fix you up.
