Re: Oil Pump Gasket
Posted by Janicholson on August 14, 2008 at 21:18:51 from (66.173.50.80):
In Reply to: Oil Pump Gasket posted by John G. Hasler on August 14, 2008 at 18:27:11:
There are paper thin gaskets between the cover plate, and the body. The gaskets are used as shims to modify end clearance of the gears. They are used in multiples. To set the clearance at less then .001", and more than .0005" JimN
