Re: Stupid, stupid carb question
Posted by ScottyHOMEy on August 15, 2008 at 05:53:02 from (71.241.219.228):
In Reply to: Stupid, stupid carb question posted by w croom on August 14, 2008 at 16:25:57:
Having to run with the choke partially closed indicates either not enough gas or too much air. Hal and the others have probably got you on the right track if it's a fuel issue -- most commonly it's the float or the flow.
As for air, check for a tight fit at the gasket between the carb and neck of the manifold, and check your manifold for cracks and to make sure it is snugged up properly to the head. It could also be a badly worn shaft or bushing on your throttle plate, but I dont think a leak of that sort would require as much choke as you describe.
One way to check for air/vacuum leaks is to get the motor running and spray some sort of fuel (carb/choke cleaner works, so does propane from an unlit torch -- don't forget to shut the propane off when you're done!) around the joints that might be leaking. Any change in the motor as you do that will indicate a leak. If it's running pretty smoothly as you do this, it will usually bog down from being too rich with the added fuel. If it's running ragged and lean, the speed will usually pick up and the motor will smooth out.
HTH
