Re: A domed pistons........
Posted by Pete in Holland, MI on August 15, 2008 at 08:34:10 from (198.36.89.9):
In Reply to: A domed pistons........ posted by Ken-Mt on August 14, 2008 at 15:24:12:
If you're going thru the efforts of assembling the pistons to see if they hit, try this die-setter's trick:
Place a layer of plastic food wrap on the piston top. Place a dob of mixed up Bondo on the wrap. Place another layer of plastic food wrap. Drop the head in place and roll the engine 2 revolutions to make sure both valves open/close. Let it sit for 20 minutes then open it up and removed the hardened Bondo. It can be cut and analized for machine clearance.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
