OEM Tractor Parts
Posted by Dan Bear Kelley on August 15, 2008 at 13:13:00 from (140.32.120.188):
In Reply to: Gauges 12 volt conversion for Super H posted by rave23 on August 15, 2008 at 12:26:35:
I know OEM tractor parts carries guages. I don't know how good they are.
On the 12v conversion... You'll need a 12v generator/alternator, a 12v starter and a ballast resistor for the coil.
Some folk say that a 6v starter will work on 12v for quite a while. There is risk there. I wouldn't go that route, but...
All the ballast resistor does for the coil is cut the voltage to 6v for the coil. Running a coil on straight 12v will burn it out FAST. You can get a 12v coil, but they're pricy.
I've seen a bunch of folk running GM alternators in place of generators. That's what I've got on my M. I've converted it to 1-wire operation with a special voltage regulator. I'm still not happy with it, but I've got other things going on right now.
Your ammeter won't know the difference between 12v and 6v.
Oh! and you'll need a 12v battery.
