Re: Gauges 12 volt conversion for Super H
Posted by John T on August 15, 2008 at 15:08:42 from (66.244.97.31):
In Reply to: Gauges 12 volt conversion for Super H posted by rave23 on August 15, 2008 at 12:26:35:
Its your tractor and your call for sure, that being said, an H ought to start, run n perform just fine at the original 6 volts PROVIDED you:
Use a good heavy duty battery (biggest n heaviest n highest rated and CCA that will physically fit in the compartment),,,,,,,,,,Use at least 0 better yet 00 gauge Battery n Starter n Ground Cables,,,,,,,Keep her well tuned (plugs, wires, points, condensor, cap n rotor)
Now if it were an M (harder to crank) perhaps I could see the conversion but that H ought to start fine even at cold temps iffffffff you do the above.
best wishes
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
