When I bought my 706 it did not have a drawbar, rather the fast hitch. I went to a junk yard and bought the 3 things you need.
1) The drawbar. My drawbar is a two piece affair. Pull a pin and the heavy iron piece pulls out allowing use of the 2 point. 2) The front mounting casting 3) A heavy bar which is bolted under the rearend,
As I remember the heavy bar has some spacers on each end with allows the drawbar to go through as well as swing from side to side. Two bolts on each side screw up into the rearend case. On the heavy bar are two blocks of steel which can be unbolted and moved from side to side to swing the drawbar.
I prefer using the drawbar to the 2 point due to it being solid. Also the 2 point isn't slapping around wearing itself out pulling heavy loads.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
