Re: IH 300 Utility 6 volt alternator wiring questions
Posted by Janicholson on August 16, 2008 at 14:42:40 from (66.173.50.157):
In Reply to: Re: IH 300 Utility 6 volt alternator wiring questions posted by fxt on August 16, 2008 at 14:14:18:
The diode does that, (assuming the #1 terminal is connected to the ignition switch, and it is coil/distributor ignition)
If it is connected to the battery, the diode will do no good. Put a switch in that wire, and turn it on when running the tractor. (A oil pressure, closed when pressure is present, switch can be used to automate that process. Those cables are too small, they need twice as much copper in them. JimN
