Re: Still having problems with my Cub Light
Posted by Jim Becker on August 16, 2008 at 15:14:23 from (71.123.128.52):
In Reply to: Still having problems with my Cub Light posted by Retcol on August 16, 2008 at 14:21:42:
Check for continuity from the lug on the back of the light to the mounting stud. If none, you have a problem in the light (bad connection, burnt out bulb . . . ). Or you can try it straight on a battery with a jumper wire.
If you have continuity, put it on the other side and see if it works.
