Re: SA 3 point conversion
Posted by Hugh MacKay on August 16, 2008 at 16:13:31 from (216.208.58.120):
In Reply to: SA 3 point conversion posted by lacash on August 16, 2008 at 06:10:10:
lacash: They will lift 500-600# provided you have the mechanical advantage correct and center point of load is within 30" of the hitch point. The Super A 3 point hitch falls fast if implement extends back too far. Be careful there are hitches on the market that won't lift half what I suggested.
