Re: I think I still have a problem with my Hydraulic pump
Posted by Janicholson on August 17, 2008 at 07:50:01 from (66.173.50.54):
In Reply to: I think I still have a problem with my Hydraulic pump posted by Idaho Ron on August 16, 2008 at 21:45:52:
If it is an "O"ring seal the housing usually needs to be machined larger at the location of the seal to allow the sleeve to enter. Tough to machine with it together. If it is a Lip type seal, it is easy, and requires no disassembly. The speedy sleeve will not fit through the end bushing of the pump, so be sure to figure that into the repair when planning reassembly. JimN
